Buzzing noise
Old Mar 29, 2015 | 04:31 PM
TankWookie's Avatar
Default Buzzing noise
My car makes what I assume to be a clutch buzz when I'm starting off from a stop occassionally, and almost every first time I go to first after starting the car warm or cold. Has only happened in first gear so far. Also, when it was snowing I took the car out to a parking lot to do some drifting and get a feel for the car. I was only touching the accelerator and the clutch buzzed a few times during my session. I cannot recall if it happened when off or on the gas. It is a 2002 with 117k miles currently. Is this the normal unavoidable buzz I've been hearing about in AP1s or is this actual signs of a worn clutch? It doesn't have any other signs of being worn like slipping or whatnot
EDIT: I found this sound clip. It has a very similar sound, except mine doesn't sound as intense, or high pitched
http://youtu.be/aVAWqNqMobM
Old Mar 29, 2015 | 04:44 PM
sam i am's Avatar
Would you consider it to be ticking? May be timing chain tension-er. They're is a youtube video about it. Sound similar to that?
Old Mar 29, 2015 | 04:56 PM
TankWookie's Avatar
No sir I also have the TCT ticking lol XP. It's definitely a buzz.
Old Mar 29, 2015 | 06:26 PM
Gotpepsi's Avatar
"My car makes what I assume to be a clutch buzz when I'm starting off from a stop occasionally, and almost every first time I go to first after starting the car warm or cold. Has only happened in first gear so far."
Clutch buzz does not happen when you are accelerating from a stop. Clutch buzz is usually during deceleration between 2 thousand and 4.5thousand RPM; the buzz is also not linked to any clutch problems. It is just a normal characteristic of the car. By watching the video it is safe to say that the noise you are hearing is not clutch buzz. I don't know what that is, but it does not sound normal.
Old Mar 29, 2015 | 07:02 PM
TankWookie's Avatar
Ohh ok. Thanks for the info. Glad to have that cleared up
Shaney
Aug 8, 2014 11:19 AM
Touge Freak
Apr 2, 2009 05:43 AM
milhouse1210
Jul 10, 2008 08:24 AM
TrueDrezzer
Sep 14, 2002 07:49 AM
Bang2nd
Jul 28, 2002 04:19 PM
