A/C
Old May 18, 2008 | 03:05 PM
chrisesteban's Avatar
Default A/C
Hey guys i just replaced my field coil and clutch for the a/c compressor. The a/c works fine but it doesnt really blow that cold like it use too. I read that when ever you do a/c service the receiver drier should be replaced. Is this common? I know that the receiver drier circulates feron through the system and gets dirt out of it so i was just wondering if any knows anything about this. Is it all neccesary to do the a/c flush?
Old May 18, 2008 | 07:18 PM
R3DS2K's Avatar
did you plug up the lines and compressor when you took it out.. your not suppose to let it expose to air for long periods of time..
if you had it exposed to air .. i would get it replaced.. also make sure you recharge it with the right amount of r 134a. more is not always better.. put in the right amount labeled under the hood somewhere
Old May 18, 2008 | 08:08 PM
Did all that but the a/c doesnt seem to stay cool for a consistant amount of time. Recharged and vacuumed the whole system. Ill probably replace the receiver its only about $50 so its not that bad. Anymore inputs guys.
Old May 19, 2008 | 07:02 PM
R3DS2K's Avatar
how did you recharge it? i know you should replace the dyer if the system is expose to air for a long time.. or if your replacing the compressor
Old May 20, 2008 | 07:03 AM
machine at my old job. replaced the expansion vavle, coil and clutch on the compressor.
Old May 20, 2008 | 06:13 PM
R3DS2K's Avatar
so any update? working good yet?
just came to mind.. why you replace all that stuff?? you sure your compressor still good after burning up the clutch.. you should have just gotten a new compressor complete
Old May 20, 2008 | 07:41 PM
nope
STS2K
Oct 27, 2010 09:30 AM
rwheelz
Jun 4, 2007 10:25 AM
BLOWNJROCK
Apr 6, 2005 09:20 PM
ninegrand
Jul 12, 2003 03:46 PM
jelliotlevy
Apr 24, 2002 05:53 AM
