A/c expansion valve.
Old Sep 7, 2025 | 01:43 PM
NoName's Avatar
I know this is an old thread, but does anyone happen to know the size of the o-rings for the connections.
I can't seem to hold down a vacuum and it was holding pressure before the change, and this is all i touched.
I didn't grab the sizes when i removed the old one (was a nightmare removal with stripped cap screw and an extractor that broke off in it as well).
And I can't find in the manual or anywhere else what size went where, and i can't figure out what else could be causing the slow leak.
I swapped out the o-rings on both lines going into the valve and on the back side. Also replaced both shrader valves.
Any thoughts or ideas appreciated.
Old Sep 7, 2025 | 04:46 PM
larry resnick's Avatar
Hi NoName,
You can buy all the O rings at RockAuto as well as an expansion valve and dryer if you need them. They are not expensive.
Larry
Old Sep 7, 2025 | 07:13 PM
Cade's Avatar
Is this what you are looking for?
https://www.hondapartsnow.com/parts-...ses_pipes.html
Old Sep 8, 2025 | 07:33 AM
thoiboi's Avatar
Originally Posted by larry resnick
Hi NoName,
Larry
yup!
https://shop.advanceautoparts.com/p/...815/10598452-P
I bought this locally because i didn't want ot wait for the RockAuto kit but it's the exact same thing.
Amazon Amazon
also available on Amazon
but truly, RockAuto is the cheapest by far : https://www.rockauto.com/en/moreinfo...13290&jsn=1082
Old Sep 8, 2025 | 12:43 PM
NoName's Avatar
Cade:
I think this is what I was looking for.
I see the parts 16 and 18 for the hoses going into the expansion valve, but not seeing what the sizes are for the other side (unless it is just the same but I was thinking they were larger). Or maybe I'm overthinking this.
Old Sep 8, 2025 | 12:49 PM
Slowcrash_101's Avatar
When you remove the o ring from the fitting, match it to one in the kit.
Old Sep 8, 2025 | 01:06 PM
NoName's Avatar
that's the problem... I pulled it and forgot to match it up
Old Sep 8, 2025 | 01:15 PM
NoName's Avatar
ok looks like I am looking at a 5/8" on low pressure side pipe, a 8mm on high side pipe and the other side are both 5/8" based on this https://www.hondapartsnow.com/parts-...er_blower.html
Thanks y'all hopefully this was my problem.
Old Sep 9, 2025 | 04:34 AM
$155 for a $45 expansion valve? LMAO is it made of gold or something?
Old Sep 9, 2025 | 06:51 AM
Hi SC,
that part is available at Rock Auto for less than $9.
Larry
