A/C Turns off while driving
Old Dec 11, 2007 | 09:03 AM
z4k's Avatar
z4k
Default A/C Turns off while driving
Well I have an 01. Over 100K. Here is what happened.
One evening I got into my car started it and tried to turn on the A/C I turn the fan up and nothing. No lights at all. I shut off the car pulled the key started it agian and nothing still. So I pull out my handy Test Light. All Fuses OK. I try one last time. Tada everything works as if nothing happened. Worked all night.
Now today(a few weeks later) I was getting into my car for lunch and nothing. Same Problem. SO I On/Off it a few times. Finally while the car is on it pops back on. So I'm driving and off it goes. Whne I got back I parked it and right before I went to tuen off the car the A/C comes back on working fine.
Does anyone have an Idea? I hope!
Old Dec 11, 2007 | 09:15 AM
8 GRAND's Avatar
Do you have a service manual? Maybe there is a relay in the loop somewhere. Sounds like a bad relay to me. Honda has been known for bad relays in the past......
Chad
Old Dec 11, 2007 | 09:16 AM
Slows2k's Avatar
So the blower motor doesn't work, not the A/C
Old Dec 11, 2007 | 10:00 AM
z4k's Avatar
z4k
NOTHING. All the light on he A/C Control area go out. Blower motor doesn't blow, compressor doesn't compress(the clutch doesn't engage), the Recycle function is inoperable.
Old Dec 12, 2007 | 02:47 AM
z4k's Avatar
z4k
bump
Old Dec 12, 2007 | 05:04 AM
MikeyCB's Avatar
Still sounds like a potentially bad fuse to me. I would replace related fuses to see if there is perhaps a broken connection that is just making contact MOST of the time.
Or maybe you have the British-designed S2K
Old Dec 12, 2007 | 05:42 AM
AssassinJN's Avatar
Well it is definitely an electrical issue, does anyone have a wiring diagram that can check where the power source for this section of the console comes from? Either it will have a fuse that may be blown, or a wire might have been clipped somehow and is shorting out. Have you done any mods/work to your head unit lately? Or any other work that you would have touched electrical wires in the last 4 months or so? OR was your head unit after market or otherwise not the one that came with the car?
Old Dec 12, 2007 | 07:39 AM
z4k's Avatar
z4k
I need to find a FSM or s site to download it. As far as installs. The car is 100% stock except for a Shift Boot and Center console cover. It is probally just a bum relay.
Anyone know where to find the FSM online?
Old Dec 12, 2007 | 11:45 AM
pjkwong's Avatar
does the fan even work?
Old Dec 12, 2007 | 01:58 PM
z4k's Avatar
z4k
Which fan? Electric cooling fan or Blower Motor for the A/C?
