cabin trunk release
Old Jan 2, 2008 | 02:12 PM
ChefJ's Avatar
Originally Posted by ShMooveS2k,Jan 1 2008, 10:05 AM
ima give that a shot thanks
UPDATE: no good the wires are still disconnected in the trunk just tried
Hooking up the positive to the fuse box and grounding the ground to the body will work. I don't understand what you are saying when you say it won't work.
Old Jan 3, 2008 | 02:14 AM
iam7head's Avatar
Originally Posted by AP1_S2k,Jan 2 2008, 04:58 AM
I dont think the s2k has one of those but I dunno
I say you pop off the plastic behind the seats and reach through there. If you have no spare tire its pretty much a straight shot
are your from canada?
i think it's a requirement after 01-02 for all us car on the road
Old Jan 3, 2008 | 04:16 AM
AP1_S2k's Avatar
I am from MD, not canada. I just have never seen one of those emergency release handles in the trunk of my car. Its an 01... I said I dunno if it has one or not though..
Old Jan 3, 2008 | 08:47 AM
ShMooveS2k's Avatar
Originally Posted by TraviS2000,Jan 2 2008, 09:54 AM
Get a better Honda dealer? I did the exact same thing, locked my only set of keys in the trunk with the car locked. My Honda dealer cut me a new key for $10 and told me to bring it back sometime with the car and they would program the key for free...
dang i just spent $65 just to get another key and its not even programmed.
i pulled out that plastic tray where the softtop sits now where is the kid nap strap? for future references.
Old Jan 3, 2008 | 08:49 AM
ShMooveS2k's Avatar
its still an open circuit because where the other end of the wires are completly off my battery so if i used the feed through wires that were in the original location it would still need to be grounded.
Old Jan 3, 2008 | 09:38 AM
MikeyCB's Avatar
That wouldn't matter. You would be completely skipping the wiring and battery in the trunk if you connected directly the the positive on the main fuse block under the hood, and negative to the chassis.
Unless you moved your entire fusebox with relays and everything to the trunk and extended your complete engine harness to the trunk (I'd bet $10,000 that you didn't do that) then you should be able to connect a battery under the hood.
Either way, you're in now. Keep a spare key outside the car!
Old Jan 3, 2008 | 10:36 AM
plokivos's Avatar
I would of ripped out the trunk and use that $65 toward a CF trunk.
Old Jan 3, 2008 | 06:53 PM
iam7head's Avatar
or just drill a hole on the spare tool well and use a stick to release the damn thing
the kidnap switch should be there for all make after 02(i think, my 02 honda has one), my 2000 s2k doesn't have one.
Old Jan 3, 2008 | 07:54 PM
AP1_S2k's Avatar
Ok I am glad I am not the only one that didn't see it. I looked today at my car just cuz of this thread and was like there is no god damn releas ein here
Old Jan 3, 2008 | 09:00 PM
MikeyCB's Avatar
I have an 02 and I dunno where the hell the release is either.
Anybody? Bueller?
