Caliper rebuild kits....need some help.
I am having some difficulty removing the pistons from the front and rear calipers. Is there a special trick with removing them from the caliper body?
The Helm's manual doesn't say but does provide an exploded picture.
Thanks in advance.
Thanks in advance.
The fronts are easy , as Chris said , compressed air in brake line fitting ( put rag under to catch piston) . Rear require special snap ring pliers , you can get pliers from Honda . ( snap ring is deep inside caliper) There is a replacement seal , where E Brake connects to rear of caliper . You need to remove snap ring from inside caliper to dissemble.
brad
brad
