CALLING ALL s2000 drive train specialists
Old May 25, 2011 | 04:17 PM
Beyond_Redline's Avatar
Default CALLING ALL s2000 drive train specialists
Ok, so I’ve been over this a million times. I’m at the point of a whole sub frame rebuild.
Took my car to get an alignment. After driving it home and to work the next day the vibration began. Massive vibration on acceleration – current and not fixed
Car is lowered and axles are spaced.
The following have been replaced:
Driveshaft
Complete diff and housing
Complete axle assembly (x2)
The following have been inspected:
Differential mounts
Trans mounts
Motor mounts
Upper, lower, and tie bushings are solid.
So I jacked the car up (safely), put it in fifth and had my brother rev from 20 to 70 repeatedly. What I found what the axles are wobbling at the same frequency as the vibration. It looks as if the axle cv joints are not spinning as they should (spins like an out of balance driveshaft at the joints).
Problem found? Maybe but how the hell do I fix it. Multiple shops have told me to turn it into a horse and shoot it.
I really need someones help here. I've done all i can do and honda will not take on the project.
Old May 25, 2011 | 06:16 PM
wrecked's Avatar
Ive heard of the axles wearing out and causing a vibration on acceleration. Try switching the axles left to right
Old May 25, 2011 | 06:17 PM
wrecked's Avatar
https://www.s2ki.com/s2000/topic/392...clicking-rear/
Old May 25, 2011 | 06:50 PM
lol I was wondering who would be the first to tell me it was the axles read the post dude! Everything about the axle assemblys are new, brand new and this didnt help at all. I guess what im asking for is some tips on testing drive train. if another person directs me to the cv swap thread I will come to your house and eat your dog! to everyone that races their S, have you ever had a weld fail on the sub frame? Everything I tap makes a ping instead of a thud... nothing looks bent... im open to pointers as long as you dont tell me to swap cv cups!
please read the Full post!
Old May 25, 2011 | 07:18 PM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
Are the axles new Honda axles or another brand?
Old May 26, 2011 | 03:51 AM
starchland's Avatar
total rear toe? alignment specs would be nice...
Old May 26, 2011 | 04:54 AM
wadzii's Avatar
Banned
If you have autozone/advance/etc reman or even new axles they could still be the cause. We have to warranty about every 5th set of axles from those places for being bad out of the box.
if you have new axles you dont need the spacers
also make sure everything is tight, the axle nuts should be 212ft/lbs and the bolts that hold the axle to the diff should be 61ft/lbs
Old May 26, 2011 | 05:15 AM
Billman250's Avatar
Top Answer: 1
Very curious on the make of the current axles.
Old May 26, 2011 | 10:42 AM
Greg W's Avatar
I think there's a cv swap thread around somewhere...did you search for it?
;-) my dog's old and I don't have the heart to put her down myself...
Old May 26, 2011 | 10:51 AM
Billman250's Avatar
Top Answer: 1
Lets wait for all the info.
