Cam Cap/Tower and Cam damage.
Old Mar 24, 2026 | 09:31 AM
zeroptzero's Avatar
main bearing damage will kill the crank as well, so might as well check that after the rods. A lot of people say rod bearings are the first to fail, but I found out the hard way that main bearings certainly fail and I found chunks of them in the oil pan when my motor failed.
Old Mar 24, 2026 | 01:30 PM
RavenYZF-R6's Avatar
Originally Posted by Billman250
The cam cap bolts were loose because the caps melted from oil starvation. This is not a bolt torque issue.
Is the front cam drive gear bolt tight? 8mm allen bolt.
I just checked and yes it is quite tight. All the cam gears look healthy.
Slowcrash_101
Apr 24, 2024 01:28 PM
slappyF20
Apr 6, 2024 08:19 PM
dbucks2k
Nov 24, 2021 06:30 AM
mrp3rs0n
Dec 5, 2016 04:13 PM
Black Nugget
Oct 18, 2005 05:36 PM
