Cam Cover Problem
Old Jun 24, 2009 | 09:50 AM
Nickamsweet's Avatar
Thumbs down Cam Cover Problem
Hey,
I recently got my cover bead blasted and then powdercoated, as i removed the packaging there were some remnants of the blasting process in the form of small abrasive beads... As I shook the cover more started to come out of the baffle section of the cover...
Now I feel I have 98% of the bits out but wouldn't mind a further way of ensuring it is CLEAN! Would pressurized air help? Or would a bath in oil be best then blow it all out with a pressurized air line again?? I was aprehensive though of using any high pressure water source to clean just incase it contaminates anything in the future... I kind of wanted to use methods that the cam cover would only see natural things e.g. air and oil...
Please Help as I want to ENSURE that it's 99.99% spotlessly clean before I install it...
Cheers,
Nick
Old Jun 24, 2009 | 11:11 AM
SgtB's Avatar
Blow it out. There are bolts to remove my baffle.
Old Jun 24, 2009 | 11:39 AM
there are bolts for mine too but the rest of the plate has rivets....?
Old Jun 24, 2009 | 04:49 PM
Kirpich's Avatar
probably secondary baffle attached to the removable primary baffle.
I can't believe you still hadn't tried it yet.
Old Jun 24, 2009 | 05:26 PM
I was going to try it but thought that it was attached so would just be pointless... found myself an air supply and blew the crap out of it!! SOO much more stuff came out... then added some oil and swished it around then blew it again to make sure everything that stuck to the oil got removed... it is now on the engine and will get pics up tooo
Old Jun 26, 2009 | 09:08 AM
SgtB's Avatar
I would have flushed it out with a water hose. Oil is sticky.
Old Jun 26, 2009 | 03:39 PM
chris_barry's Avatar
Its safe to flush with water and degreaser. You need the volume of water to flush any debris out.
To dry it, flush with hot water and blow off with air.
Old Jun 26, 2009 | 03:46 PM
simoncb900f's Avatar
run it thru the dishwasher a few times.
don't tell the skirt.
Old Jun 26, 2009 | 08:31 PM
SgtB's Avatar
Bead blasting material isn't too good for your washer drain, and engine oil doesn't go in the sewer. Just saying.
shift957
Nov 11, 2014 02:19 PM
sanjuro
Feb 13, 2014 01:39 PM
05TurboS2k
Jan 14, 2008 08:12 AM
RainMeister
Jul 10, 2005 05:57 PM
devilchrist
Jun 7, 2004 01:36 PM
