CAM GEAR OEM
Old Nov 22, 2006 | 06:42 PM
CaymanS2k's Avatar
Default CAM GEAR OEM
hey, anyone look at a oem cam gear and see that it looks like it has 2 gears put together. well my cam gear is not lined up. Anyone know how this could of happend and can a machine shop fix it? its the teeth on the cam gear.
please let me know asap.
webster.me@gmail.com
Old Nov 22, 2006 | 07:54 PM
Stratocaster's Avatar
There is two cam gears and one drive gear that the chain rides on. What do you mean, not lined up? When the crank is top Dead Center, the drive gear's marks should be level with the head. The Cam gears marks should be level with each other. If it is off, you have to get it fixed.
So has the head or cams ever been off of the car?
Old Nov 22, 2006 | 08:52 PM
mxt_77's Avatar
I think he's referring to the cam gears themselves... they are a split/two-piece design and have some sort of spring that keeps them aligned. By "not lined up", I'm assuming that he means the two pieces are no longer "in sync", so the front part of the gear is misaligned with the back part.
Here's a pic for reference:
Not sure how they are connected exactly, or how they could become disconnected.
Old Nov 23, 2006 | 03:25 AM
CaymanS2k's Avatar
yes exactly. the camgears look like there are two connected to each other. the smaller back part of the gear teeth do not align with the front half teeth. can a machine shop straighten this out?
Old Nov 23, 2006 | 03:31 AM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
There's nothing to straighten out. The back part and the front part are supposed to be misaligned, that's how the gear dampens itself.
Unless the one tooth is sitting dead in the middle of two teeth, then the gear is junk.
Old Nov 23, 2006 | 04:20 AM
CaymanS2k's Avatar
it looks like someone twisted it a little, and they are a few mm off. the teeth dont line up on the cam gear. The only reason i'm asking if a machine shop can fix it, is because i'm over seas, and it takes 2 to 3 weeks before i can get anything here. sux only having one s2000 on the island. I have to order everything from either japan or the US. and it takes forever
Old Nov 23, 2006 | 06:03 AM
SpitfireS's Avatar
CaymanS2k Posted on Nov 23 2006, 02:20 PM
Any pictures?
The way I understand it, is that the cam gear "straightens" itself out when it is "in gear" with the idler gear/cam chain sprocket.
Does your cam gear doesn't do that?
Old Nov 23, 2006 | 07:57 AM
mxt_77's Avatar
I'm confused... from the pic, you can see that mine are properly aligned up there.... even when I had them out, they were still aligned just like that.
Old Nov 23, 2006 | 08:03 AM
CaymanS2k's Avatar
you see how the cam gear looks like two cam gears are put together, well the smaller part of it is a few mm twisted from the front teeth. i dont have a pic of it. sorry
Old Nov 23, 2006 | 08:04 AM
mxt_77's Avatar
[QUOTE=CaymanS2k,Nov 23 2006, 11:03 AM] you see how the cam gear looks like two cam gears are put together, well the smaller part of it is a few mm twisted from the front teeth.
