Camber Adjustment?
Old Mar 5, 2004 | 05:53 PM
ATXS2K's Avatar
Default Camber Adjustment?
From what I have read so far, camber IS adjustable both front and rear. Correct?
If YES :
Is there a "DIY" on this? Mainly I just want to know the points of adjustment. Are there any pics of them? I AM NOT GOING TO DO THIS IN MY GARAGE. I just want to make sure that I get it adjusted after I install the Neuspeed Springs when I take it to NTB to get alligned.
If NO :
What camber kits are available, that people have used, and can someone supply a link?
THANKS IN ADVANCE!
BTW I have used the search, and found OBX FRONT camber kit, but it was suggested to be "crap". I also found that our cars are capable of camber adjustment, but there was no solid proof.
Old Mar 6, 2004 | 02:14 AM
ReedZ's Avatar
Former Sponsor
YES. Camber is adjustable both front and rear on the S2000. I don't recall seeing a DIY on alignment here, the S2000 is very sensitive to alignment settings. Be sure not to drive too far after lowering, in many cases (mine included) your alignment will change significantly after lowering. For example, my caster was 7.3 degrees (moved from 6.43) and my rear camber moved to 2.8 (up from 2.3) after lowering just over 1/2 inch.
Old Mar 6, 2004 | 08:11 AM
ATXS2K's Avatar
Cool, thank you!
I didn't plan on driving but to the NTB IMMEDIATELY after lowering. From previous Honda's I have learned to get them alligned asap when lowering.
I hope the guy I am going to knows how to adjust everything correctly...
...maybe I should give him some credit.
Again, if anyone else has info on where the adjustments are made, I would really appreciate it. Thanks again!
samson123
Aug 24, 2017 10:19 AM
seansniper
Jan 19, 2012 04:08 PM
Dr Jekyll
Jul 24, 2007 07:23 PM
S~Factor
Jun 12, 2007 04:23 PM
TunedS2000
Jan 14, 2005 07:06 AM
