camshaft install and timing
Old Jun 6, 2006 | 11:26 PM
dupak633's Avatar
Default camshaft install and timing
anyone knows the proper f20c camshaft timing
Old Jun 7, 2006 | 09:06 AM
dhayner's Avatar
From Helm:
1. Number 1 piston at top dead center
2. Both marks on upper chain sprocket even with cylinder head upper surface
3. Marks on cam gears at 3:00 and 9:00, pointing exactly towards each other
Old Jun 13, 2006 | 03:29 AM
dupak633's Avatar
is there a need to align the timing marks on the timing chain and on the chain the drives the oil pump?
Old Jun 13, 2006 | 06:19 PM
dhayner's Avatar
From what I can see, there is no alignment requirement for the oil pump chain.
With the #1 piston at TDC, the timing chain lower sprocket/crankshaft key should align with a pointer on the block - no choice here, it's made that way. Then put the single colored link of the timing chain at the punch-mark on the lower sprocket. Finally, put the punch-mark on the upper sprocket between the two adjacent colored links of the timing chain.
With the upper sprocket turned CCW only enough to take the slack out of the chain, the marks on the sprocket should be even with the upper surfacace of the head, as mentioned in my first post.
(Here Helm concludes with a paragraph I don't understand: "If the timing chain sprocket is not positioned at TDC, remove the idler gear from the cylinder head and reposition the timing chain to bring the timing chain sprocket to TDC." Maybe that is to account for chains that may have had links added or removed between the single and double colored links.)
Silver_Bullet_S
Sep 24, 2018 07:24 AM
macr88
Engine
Jan 28, 2010 12:25 AM
KDuke
Jan 23, 2002 07:34 PM
