Can EVAP CEL (P1457) cause cylinder misfire code?
Old Mar 24, 2012 | 03:56 PM
hrpfg2's Avatar
Default Can EVAP CEL (P1457) cause cylinder misfire code?
Recently, Check engine light came on. So I had the codes pulled and it was the EVAP, misfire in all cylinders and random misfire. (nothing changed as far as how the car feels)
Before I had time to really look into the problems, the CEL went away on its own. (yay!)
A few weeks later the light came back on and so I pulled the codes again. same codes.
Do you guys know if EVAP failure can cause misfire codes? Can these codes be related?
Thanks!
Old Mar 24, 2012 | 10:40 PM
Kirpich's Avatar
Just thinking out loud, try checking the valve on the back of the head, by the firewall, on top, and the hoses leading to/form it. If there is a leak, then there is going to be unaccounted-for air in the manifold, which could make the engine act a bit different, and be interpreted as knock.
Does the car idle fine? When engine is cold, hot? Top-end power is good? Or stumbles and hesitates?
Check all hoses, and I mean all, for bad fit, loose, cracks, etc.
dsutton01
Oct 30, 2007 08:40 AM
damsas
Nov 17, 2006 08:03 PM
folex187
Nov 11, 2005 02:35 AM
