Can I mix synoil with another synoil?
Old 03-02-2004, 05:12 AM
Former Sponsor
jwkim's Avatar
Default Can I mix synoil with another synoil?
My car has Mobile1 10W30 right now but
I recently moved to korea and here they dont have Mobile1 10W30.
My oil level is little low and I bought Motul 10W40.
Is it ok to fill up with Motul?
Old 03-02-2004, 06:12 AM
silvershadow's Avatar
Road Rage appears to be the resident oil expert. You might want to PM him with your question.
Old 03-02-2004, 08:03 AM
jeffbrig's Avatar
No!!! They will mix and immediately coagulate into a heavy gel, and eventually set like a 2-part epoxy!
j/k, shouldn't be a problem mixing, the additives will blend, so you'll have a little of the properties of each, sort of a 10W32(ish). I'm sure Road Rage will respond with a MUCH better technical answer.
Old 03-02-2004, 09:12 AM
xviper's Avatar
[QUOTE]Originally posted by jeffbrig
No!!!
Old 03-02-2004, 02:06 PM
TrueDrezzer's Avatar
You should be fine.
Pick an oil (like the 10W-40 you mentioned) with the same or higher viscosity range than what's in the car. Don't pick something with less.
i.e. if you had 10W-60 in the car and topped up with 10W-40, your effective viscosity is closer to 10W-40.
///Robin
Old 03-02-2004, 02:16 PM
Road Rage's Avatar
Perfectly OK to do so - but I would not play chemistry roulette all the time by mixing different products. They are engineered to perform in the proportions of PAO/ester they contain. Mobil1 uses a small amount of ester to ensure seal swell to offset the tendency of PAO to shrink seals. The amount of ester is unknown to me. My guess is it is less than the 15% estimated to be in the R formulation.
Motul is terrific oil.
Dracoro
07-31-2003 04:55 AM
amongmany
07-14-2003 07:51 AM
wiseman299
04-10-2003 09:14 AM
Hairy Beanbag
08-25-2001 02:24 PM
redleader
05-08-2001 08:51 AM
Quick Reply: Can I mix synoil with another synoil?
