can someone explain 4.44?
Old Nov 14, 2002 | 01:37 PM
david spell's Avatar
Default can someone explain 4.44?
i'm just curious bout it. how much it cost, the performance factor/stats, and what it consist of exactly.
thanks for any input.
Old Nov 14, 2002 | 02:05 PM
Schatten's Avatar
its a ring and pinion gear for the rear end, which changes the final drive ratio in the car - doesn't change anything inside the transmission, only in the differential housing.
our stock piece is a ratio of 4.1 and this is a ratio of 4.44.
cost is $920 delivered to your door.
xviper has some good information on performance gains and installation as well. but I do not recommend self installation of the gears unless you have the proper equipment and have done this before. cost of instllation should be around $350, or at least no more than that.
Old Nov 14, 2002 | 02:30 PM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
to add, it will give you faster acceleration, more pull at low rpm's, but maybe a sacrifice of some top speed MPH.
Old Nov 18, 2002 | 02:33 PM
Tryzub's Avatar
Is it feasible to swap to a J's Racing 4.44 rear gear AND add a supercharger? How about a turbo with the 4.44?
-Tryzub
Old Nov 18, 2002 | 02:48 PM
Schatten's Avatar
yup, you can do that. there are SC owners w/4.44's out there. its up to you and your needs/purpose.
Old Nov 18, 2002 | 08:40 PM
xviper's Avatar
[QUOTE]Originally posted by Tryzub
[B]Is it feasible to swap to a J's Racing 4.44 rear gear AND add a supercharger?
Old Nov 19, 2002 | 11:52 AM
Fanman's Avatar
Would this make you idle higher ? What would the disadvantages be ? less mpg ?
Old Nov 19, 2002 | 11:59 AM
jefftse's Avatar
I thought it will only effect the final gear.. how can that change your accel.?
Old Nov 19, 2002 | 12:02 PM
Schatten's Avatar
this is in the rear end, so it doesn't effect anything regarding idle. when idling your transmission does not engage the rear end, which is where the gear is, so not effected.
yes, it will clip a few miles per gallon.
trust me, it will affect accelleration. you'll go through gears faster and reach the top speed quicker (although that's clipped a little as well)
Old Nov 19, 2002 | 12:25 PM
xviper's Avatar
It's like going to a bigger sprocket on the back wheel of your bicycle. The gears that your pedals are attached to (equivalent to your car's tranny) do not change (ie. not affected) but you can pedal easier and thus get going quicker.
