Can a valve adjustment cause a CEL?
Ok. It's weird, it only comes on every few days. I recently replaced the cylinder head. The CEL never came on before that. After I reset the ECU it runs normal. It's only twice over the last week.
What about "hot spots" on the cylinder head? The head I put on had some dings on the quench area.
Here's a link to the post I started:
https://www.s2ki.com/s2000/topic/955...cylinder-head/
Thanks for the help.
I'm going to check the sensor in the morning. I hope it's just a bad sensor.
I'm going to get a valve adjustment done at the dealership on Monday. I did it my self, but I want to be sure.
My car still pops (misfires, but no CEL), but it feels stronger after replacing the head.
I'm going to see if the Cat is clogged also.
I thought my misfiring was from burnt valves. I had low compression and when I did a leak down test I could hear air leaking from two of my cylinders into the intake manifold.
I replaced the head (valves were white), but the popping/misfireing is still happening. It's not loud like a back fire, but softer. No smoke or anything like that.
I'm going to do another compression test tomorrow.
Could the popping be related to the CEL for the knock sensor?
