Can we get confirmation on....
Old Jun 25, 2001 | 10:13 AM
krazik's Avatar
Administrator
Default Can we get confirmation on....
Do we or do we not have a Mazda rearend?
Anyone have any friends with a Gen 3 Rx7 that we can look at?
They have Rx7's with 400+ hp. So if we really have the same (or similar) rear end, I don't see why I can't swap mine out with a beefier aftermarket Rx7 one.
Old Jun 25, 2001 | 10:55 AM
Schatten's Avatar
gotta friend here at work who mods out RX7's, inquiring and will post if I find out anything.
Old Jun 25, 2001 | 01:29 PM
Schatten's Avatar
yea, I thought it was the same as the Miata, but didn't want to spread a bad rumor. thanks for the clarification.
Old Jun 25, 2001 | 02:19 PM
krazik's Avatar
Administrator
anyone with a miata that can confirm it then?
Old Jun 25, 2001 | 08:37 PM
jschmidt's Avatar
According to the website, it looks like a lot of great cars are using this diff.
Old Jun 26, 2001 | 01:52 AM
tsw's Avatar
tsw
i thought in another thread, it was mazda that put the thing together?? so the only common factor is the torsen thing?? but different manufacturers put the differential together?
Old Jun 26, 2001 | 04:26 AM
cmnsnse's Avatar
I think most of us are worried about the complete assembly - not the limited slip part.
Once we find out specs' we might be able to just do a pretty simple swap, maybe an adaptor for the driveshaft - and joints/axles
What is the RX7 geared at?
Old Jun 26, 2001 | 10:10 AM
tsw's Avatar
tsw
yeah, that's what i meant.
it doesn't matter if it's type I or type II, it's the construction of the whole assembly.
Old Jun 26, 2001 | 05:59 PM
Windscreen's Avatar
I just traded my '94 RX-7 tt on my new Stook. Having spent numerous hours under my RX , I can say for certain that the housings between the two cars are very different.
Obvious differences:
-the RX's companion flange is a more conventional 4 bolt hook-up with regular universal joints
-the S2k has a MUCH more heavily finned aluminum section
-the RX's housing vertical split line was much further rearward (the aluminum part was just a cover, not really a load bearing part)
-due to this split line location, the RX housing is a larger percentage cast iron
-the snout of the RX differential had a substantial boss for bolting to the PPF (power plant frame - a large, truss bridge like structure that rigidly tied the trans to the diff)
The RX-7's final drive ratio is 4.10:1 (same as the S2k), but the Torsen unit is the better type 1 (higher available torque bias).
So, if they do share any parts, it would be limited to ring, pinion, and the bearing & shim arrangements. I do remember reading somewhere (probably a year ago) that Mazda was building this differential unit for Honda.
I will also say that I am quite surprized how big the S2k's half shafts are (36 mm solid according to Automotive Engineering, August 1999). These are significantly thicker than the RX-7's.
Finally, for all the techies, I have in my possesion an SAE paper "Development of the High-power, Low-emission Engine for the "Honda S2000"" with my notes from when it was presented in Detroit by the project chief engineer. I also have a nice article from August 1999 Automotive Engineering International on the car. I could be persuaded to scan these in, if someone would provide the space to host the scans.
Windscreen
2001 Yellow
Old Jun 26, 2001 | 07:01 PM
krazik's Avatar
Administrator
I will host the scans here.
e-mail them to me
rylan@rylan.org
dillonkennedy003
May 2, 2015 09:43 AM
speakeasy2009
Aug 9, 2013 03:55 AM
exodusx7x
Dec 13, 2012 03:27 PM
gomarlins3
Dec 8, 2005 02:15 PM
chris_barry
Jul 4, 2003 01:24 PM
