Cannot do stock alignment on lowered car?
Old 02-10-2006, 10:13 AM
24s2k7's Avatar
Default Cannot do stock alignment on lowered car?
There are only like two places in my area that can align lowered cars. They said I have to bring in specs before they can align it since it is lowered. How do I know what specs to use?
I have koni yellows(lowest perch)/espelir springs so it is almost 2" lower.
Any help would be greatly appreciated!!!
Old 02-10-2006, 10:55 AM
rlaifatt's Avatar
wrong forum if you want stock alignment.
Old 02-10-2006, 11:19 AM
24s2k7's Avatar
I can't get a stock alignment if I wanted. I need some information on how I can know what alignment to get with my setup. They need me to bring is specs since my car is lowered, how do I know what specs? I know nothing about specs. My rear comes out pretty easy, even with a hard 1-2 shift going in a straight line. Anyone with koni/espelir have some specs I could use? I want the specs to be good for handling but not too aggressive.
Old 02-10-2006, 11:43 AM
mikegarrison's Avatar
Wrong forum period.
Not to be too cold about it, but you are asking the wrong people about "specs to be good for handling but not too aggressive".
Old 02-10-2006, 02:29 PM
Administrator
krazik's Avatar
yeah not to mention, what place claims they can't align a lowered car. The alignment process is the same, lowered or otherwise. And their computer has the stock specs.
Old 02-10-2006, 03:30 PM
Administrator
cthree's Avatar
Indeed. Find a different shop.
Moving to Under the Hood
Old 02-10-2006, 04:35 PM
CosmosMpower's Avatar
With a lowered car you're bound to have some extra and probably unwanted camber. See if you can adjust the camber/toe back to or close to factory specs. The back end being squirley is probably due to rear toe out right now.
Factory (UK) is:
Front-
Camber -1 degree both sides
Caster- Max it out (between 5.5 and 6.45 is acceptable)
Toe- 0
Rear-
Camber -2 degrees on both sides
Toe- .20 toe in each side (.40 total)
Old 02-11-2006, 01:15 AM
Administrator
krazik's Avatar
ROFL unwanted camber.
on the s2k you can never have too much. If your tires are wearing on the inside, just drive on windy roads only.
Old 02-11-2006, 02:40 AM
Administrator
cthree's Avatar
This is true. Optimum camber settings for performance are -4 front, -3 rear. Not the best for even wear but certainly the best for performance. My settings are:
Max castor (you'll get more out of the right than the left), make them even.
Max front -camber so they are even
Max rear -camber so they are even
A touch of rear toe in (0.40" total)
No front toe.
You'll probably get -1.8 front camber, 6.5 castor, -2.5 rear camber but it depends on your car.
Old 02-11-2006, 09:00 AM
Administrator
krazik's Avatar
There is no such thing. The correct camber is going to depend on tire type, wheel size, spring rates and other stuff.
But yes our car responds well to over -4 in the front.
Quick Reply: Cannot do stock alignment on lowered car?
