Cannot seem to get rid of O2 CEL
I am going to try removing the defouler insert, so I still maintain the distance but have a larger opening. I went from somewhere around 1/4" to 1/8" and now to the smallest 1/16", so you guys may be correct in that I was heading the wrong direction. My hope is that the water toasted the first sensor and this is just a separate issue related to he test pipe.
Have you tested the sensor?
Your codes are NOT related to having a TP. You have a circuit and heater malfunction. You're chasing this the wrong way.
A TP related CEL would be a P0420, catalyst efficiency code. That means that the ECU has detected that the secondary O2 is reading is the same (too similar) to the primary O2's reading...which would mean the cat is doing nothing....which it isn't...because there is a TP there.
Your codes, however, signify other issues.
Your original O2 code probably was a P0420. This could have been fixed using a defouler. The puddle was non-consequential. Its a car. It goes thru puddles all the time.
You then bought a new sensor, which was faulty...or there is something wrong with your AFC tune.
Check the resistance values on your O2 sensor. The values and procedure are in the shop manual. Do they match?
