CAN'T GET REAR TO ALIGN
Old Jul 25, 2005 | 05:30 AM
FASTSIIK's Avatar
Default CAN'T GET REAR TO ALIGN
i few weeks ago i lost control in the rain and got the whole car up on a curb, not much rim damage but some. I got it on the alignment rack but i could not get the rear in spec, so i know i need to replace some parts but i cant see anything bent, both sides are toed in 2 degrees, and have -2.5 degrees camber. and that is even when the toe adjustment shim is at its lowest point. i also have bearing noise so i know i at least will need a hub, spindle and bearings, but i need to know what part (if damaged) would be most responsible for the toe in the rear? cause nothing looks bent and i dont know what to buy. someone please help cause its just chewin up my tires they are almost bald, i've lost almost all my tread in less than 4k miles.
Old Jul 25, 2005 | 07:05 AM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
Bent spindle/knuckle...see it all the time
Old Jul 25, 2005 | 09:07 AM
FASTSIIK's Avatar
thank you so much man! just saved me alot of money! are you a honda tech?
AZS2KDancer
Jun 1, 2016 06:28 AM
muha22752
Oct 14, 2012 03:01 AM
JVS2
May 26, 2009 10:02 PM
skynetop
Sep 16, 2005 03:17 PM
xda2000
Nov 29, 2004 03:31 PM
