car is bogging
Old Oct 16, 2007 | 12:51 PM
00_nfr's Avatar
Default car is bogging
as the topic implys my car has started to bog while driving. At first i thought i might have been low on oil ( which was true) so i did an oil change that day using Mobil 1 and it hasn't stopped. The car ONLY bogs while i'm driving and even then it doesn't do it very often. I'm just worried this could be the start of something bad. should i just do a tune up (ie. plugs and wires and what not)? cars got about 85km on it.
thanks for any help
Old Oct 16, 2007 | 02:24 PM
NVMY4N's Avatar
Angry
CLICK HERE.
Old Oct 16, 2007 | 06:22 PM
00_nfr's Avatar
sorry man...New to the site bro
Old Oct 16, 2007 | 06:43 PM
slalom44's Avatar
Top Answer: 1
You might want to be more descriptive: Does it bog when you are accelerating at high RPM? Is it when you're just cruising? When you're accelerating from a stop? When you're creeping along at slow speeds? Does it happen in certain weather? Is the engine warm or cold?
Old Oct 16, 2007 | 06:55 PM
jray8's Avatar
keep me posted, im having the same problem periodically when the car is fully warmed up, i can have the car in cruise control at about 70-80mph then is starts to cut out and feels like a 2cylinder engine. after it starts it does it at any rpm and also in neutral, replaced map, checked coils, ran seafoam through tank, still does it. im curious to know what you find!
Old Oct 17, 2007 | 05:57 AM
slalom44's Avatar
Top Answer: 1
Are you getting a CEL? If not, you might have a lot of crud in your gas tank plugging up your filter.
Old Oct 17, 2007 | 02:35 PM
00_nfr's Avatar
since it started to bog (friday) i haven't really pushed the car real hard. So to reply to your statement, it bogs while i cruise periodically...i've had the car bog in every gear at different times..I always warm up the engine before it moves so i can assume thats not a problem. I read the FAQ page and my first assumption would be the weather change as i live in canada and am gettin ready for the cold weather.
pokemonster
Nov 17, 2013 09:18 AM
CLEANs2000
Oct 6, 2009 08:50 AM
pinoyk20
Jan 24, 2008 11:03 AM
kntrider
Sep 29, 2006 07:21 AM
adb280z
Jan 17, 2004 06:03 AM
