car cranks but wont start
car cranks but wont start i've changed the fuel pump, fuses and battery and still good amount of petrol still in it.
started last night but when i tried to turn it on this morning would only crank but not turn over but now its not priming either, i checked the fuses again replaced the battery too but still wont start
cant figure out the problem can anyone help?
please and thank you in advance
At the risk of sounding jarsh, you don't seem veey good at diagnosing (throwing random parts at it hoping one fixes it is not diagnosing). It hurts thinkong of all that time and money wasted.
Lets try to make it easier. Lets first rule out fuel. Get a can of starting fluid. Remove air filter. Spray a long squirt into intake. Does it start now, at least for a sec or so? If so, its a fuel problem (not battery, not electrical, etc). Of not, and if you did a looong spray into intake with filter removed, then immediately tried to start and it didn't, you have a fuel delivery problem.
Troubleshooting is a needle in a haystack. Keep making the haystack smaller by isolating. To start, an engine needs fuel, spark, and compression. And timing of spark. Narrow it down to one of those first.
So my 05 is in the shop right now for the same issue(i think). Started out with electronics(ignition) checked battery(was failing so replaced), still didn’t work. Have looked at further ignition conditions. Starter is fine, spark plugs are good, immobilizer does not seem to be giving issue. Talked with some other technitians and was told to check another ignition relay(common failure in Honda’s), found wires had failing connection points, soldered new connections, but those didn’t hold, so replaced the relay entirely. Fuel pressure regulator was found to be leaking somewhat so that was replaced. Cam sensor was also causing rough(bogged) start, so that was replaced. There was still a drop in voltage upon crank so new/additional grounding was wired and voltage drop has decreased significantly to be back in factory specs. Was told to come pick up the car and as luck would have it it’s still wonky starting, so now the rest of the fuel system is next on chopping block. Might have an update after shop calls me tomorrow. Glad i have a shop that’s taking their time to test everything methodically but I’m fearing my problem is leading down a deeeeeep money pit.
Their stories sound so good to you, so convincing, because they have a lot of practice at weaving such tales...
