car was overheating
Old Jul 28, 2009 | 08:45 PM
s2guru's Avatar
Default car was overheating
So my turbo coolant lines were leaking for some time, but very small leak ( so i thought ) i used the check the coolant level in the overflow thank every 2 days, and it was fine.
my ECT just broke ( it would show 4 bar right after i start up the car ) the other day i notice the bars went from 4 to 5 and 6 in traffic.
so i parked the car in my house and went to check the coolant on the radiator, the coolant was very low, took 1 full gallon to fill up the radiator.
So now i'm thinking what damage was done to the engine while the car was overheating. Where should i check?
my coolant setup.
koyo rad + koyo cap
spal dual fans
spoon thermo, spoon switch
samco radi hoses
if it help i have a laskey built block.
Old Jul 28, 2009 | 09:24 PM
drexelmech's Avatar
dont know much about ur turbo setup, but those mods should be able to cool almost any motor. Due to the fact that it reads high right away might mean ur either really low on oil or your thermostat is malfunctioning. Should take the motor some time to heat up after startup without the coolant system doing anything so i wouldnt say its coolant but ive been wrong before and ill be wrong again.
Old Jul 28, 2009 | 09:29 PM
s2guru's Avatar
i'm not running the stock ECU, i have the EMS thats why i have the ECt.
when i checked the coolant on the radiator was very low, again it toke 1 gallon of coolant to fill up the radiator again,
i need to know how to check if any damage was done.
Old Jul 28, 2009 | 09:38 PM
drexelmech's Avatar
i would atleast check all ur gaskets because overheating would increase pressure which generally results in gasket failure, other than that i cant really help u sry
Old Jul 29, 2009 | 02:34 AM
Fast Jack's Avatar
Welp,u've fixed your leaks and top off the coolant.Like he said,check for any leaking gaskets.If that's all good,compression and leak down test should tell ya if there's any damage.Check your oil,if it smells burnt,change dat also.Anyone else care to chime in? Also,post up on the the FI forum,bet they've got some stories to tell.
Old Jul 29, 2009 | 04:13 AM
s2guru's Avatar
i'm doing today , thank god the koyo take almost 3 gallon of coolant, and i it was missing only 1.
braeden
Jul 18, 2015 12:54 AM
S2000_FUN
Mar 16, 2011 12:34 PM
Competitor9
Jan 29, 2011 05:22 AM
S2Gizzle
Apr 5, 2010 11:28 AM
midwesta
Sep 28, 2009 04:11 PM
