Car Pops when Idling
Old Jul 28, 2010 | 11:28 AM
03_BB_S2K's Avatar
what do you mean you're not throwing any CEL only for your intake? Maybe you have multiple codes that are in the ECU but you seem to think it's because of the intake. Go get the codes read. If you think it's the intake, why don't you fix it to see if the CEL goes away? I hate to be in your shoes right now buddy but good luck
Old Jul 28, 2010 | 11:43 AM
Dumas2k's Avatar
P0410 is the code, I did have a CAI but went back to stock. Then the cel came on. Ill get it Cel pulled again.
thanks
Dumas2k's Avatar
i will be getting a valve adjestment this weeked, my car has 115k miles
Old Jul 28, 2010 | 12:40 PM
turbo_slug's Avatar
Originally Posted by hypforlife32,Jul 27 2010, 09:56 PM
do you have a video at all that you can post up??
i knot a bad coil would cause a misfire and that would make the car run like a wrx and feel super slow.
i bad injector wouldnt pop i dont think because you wouldnt be getting enough fuel to push extra fuel through the motor to combust giving you a pop.
bad retainers would drop a valve causing one to be bent/drop... it wouldnt be drivable.
dropped valve would not be drivable at all.
im just throwing a few ideas out there.
when my car was misfiring, it made popping sounds from the exhaust.
to be on the safe side, i did a compression test, leakdown test, valve adjustment, retainer inspection etc...turned out to be bad fuel injectors...
Old Jul 28, 2010 | 04:48 PM
Dumas2k's Avatar
ok just got back from autozone had 2 cel codes
1.)p0410
for the intake
New to Me.(After Installing The test pipe.)
2.)p1399
Random cylinder misfire
Blocked EGR passage
Valve clearance out of range
Dumas2k's Avatar
Is there a test to check if the injectors are bad
Old Jul 28, 2010 | 06:17 PM
Dumas2k's Avatar
how much would a valve job usally cost
Old Jul 28, 2010 | 07:05 PM
ChefJ's Avatar
vvalve job at stealership is about 120 bucks. p1399 is random misfire. Interesting that it didn't single out any particular cylinder.
Old Jul 28, 2010 | 07:50 PM
Dumas2k's Avatar
well im getting a valve adjustment this weekend. ill keep yall updated
Old Jul 29, 2010 | 12:53 AM
turbo_slug's Avatar
Monitor fuel trim using an obd2 scanner
