Car running a bit hot
My car is running a bit hot.It is usually between 190*F (87*C) and 205*F (96*C), but can some times go up to 220*F (104*C). It happens both when going slow, and under normal highway driving ~60mph. The coolant level is at the correct level, and the thermostat is no more than 3 months old (OEM Honda). What could be the reason for this? Any suggestions?
^^ I agree with above to make sure the cooling plate is in the right place and that the radiator and/or fan is fine. Maybe the water pump isn't applying enough pressure to the cooling system? When you find out, report back. I'm curious
Honda considers anything below 235F "not overheating." 220F is certainly within the bounds of normal operating temperature. It is perfectly normal to have the coolant temp go up and down depending on whether you are stopped or going fast or slow or driving the car hard.
This is a great example of why OEMs use dummy gauges instead of real gauges.
you indicated bleeding the system more, did you recently change the coolant or change the radiator?? If so ANY bit of air in the system will cause the temperature to jump. I put a new rad in mine and the first time i drive it the temp indicator went up to 5 bars so i shut it off and coasted to a stop. the Heater Core held air and the system required additional bleeding, just n FYI
How can I check the water pump?
