Car is shaking....
When im letting go of my clutch, it has to go fairly high to start moving and then the car starts shaking (sputtering) like it wants to turn off.
About 3 months ago I changed the flywheel/clutch on the car from stock to ACT.
The car has been doing this for about 9 months now.
Its really starting to annoy me.
I really need some help guys.
Someone had mentioned motor mounts ? or the whole re learning the ecu process?
My friend has the same exact s2k, same yr, and 45k miles with no air pump and he doesn't have this problem at all.
My car is stock now except air pump removed. (It did this when air pump was on aswell)
Please help guys.. i have a my03 with 42k miles (routine maint always completed, every 20k miles.. diff, tranny, new plugs, etc)
Possibly.. But it was doing it stock.
Then I did Act Lightweight flywheel, Act PP, Act Street Disc...
The first week it was fine..
Then it started doing it again when it broke in..
if you say it was fine right after the clutch replaced, then it would be your clutch, flywheel etc. if you are talking about vibration at the clutch pedal, you might want to start checking your reservoir fluid level, bleed ,
remove the shift fork and lube it with high temp grease at the tip where the fork touches the throw out bearing. Few ppls don't lube the throw out bearing and main shift spline cause very hard pedal after short period of time. If you are taking about clutch chatters when engaging the clutch, your pressure plate probably overheated, thats not much you can do about it unless you resurface or replace the flywheel/clutch.
How light was the flywheel you had put in? Sounds like you might need a few more rpm to take off as lighter flywheels store less kenetic energy to keep rotating.
The high clutch engagement might just be a adjustment problem.
