car wont idle
Ok, just got an 01 and it has been running fine. It had a broken knock sensor that was not plugged in when I bought it so it threw the light for that but it didnt seem to affect the way the car ran for the first week and a half I had the car. A few days ago I went to pull it out of the garage and it started right up, I pulled it out and walked into the garage for a little bit and then it cut off.
It will start up but it will not idle now. When I run it I have to keep the revs above idle for it to run, and it throws 5 codes.
Cylinder 1 misfire, Cylinder 2 misfire, Cylinder 3 misfire, Cylinder 4 misfire, and Random/Multiple cylinder misfire.
It is not the map sensor, tps, iac, ect.
I am wondering if the knock sensor could be causing this?
Any input would be great, thanks
KS will NOT cause that
try isolating which cylinder is causing the issue
pull coils pull the plugs have a look at them swap them 1 at a time in different spots to isolate the specific faulty plug or coil
The knock sensor adjusts ignition timing to reduce knock. A faulty knock sensor could certainly be the source of your problems. But the way you are describing it makes it sound more like a fuel pressure or air starvation issue.
I'm assuming since you said the MAP, iac, ect and tps are not the issue, you tested them?
Once the ecu sees faulty readings from the ks it stops using ks corrections
It is not the issue but it won't hurt to fix it eBay has them new with warranty for $30
As far as map tps ect I have never in I don't even know how many Hondas I have worked on fail unless it was physically broken.
It's fuel or spark
It's fuel or spark
It's fuel or spark
It's fuel or spark
OP, Did you plug in the KS of leave it unplugged?
