Car wont start......
I was driving home today and i smelt gas as im driving. I thought it was from the inside of the car b/c i was helping a stranded bystander on the side of the road cause she ran out of gas. And i spilled gas on me. So I driving semi aggressive but not redlining it. When i get to the light my clutch is shaking and my car died. I have a problem when i had my clutch installed and when i would drive aggressive and hit high rpm the clutch would decline a bit. I just had the battery and alternator changed out and now the car wont even crank. I've tried to jump it. and now when i step on the clutch it harder then what it usually is and it makes a squeaking noise. I also changed out the slave and master cylinder recently.....please help this is giving me such a headache
Originally Posted by Davidletran,Feb 20 2011, 08:05 PM
Flywheel might be bad like someone posted earlier or starter is bad
Originally Posted by Davidletran,Feb 20 2011, 09:36 PM
Usually auto part stores will check it for free, but since our starters have their own zip code, it'll be a tough one.
check for three things compression, spark, and fuel...this meaning the coils and spark plugs for spark portion...also the starter if it is making a noise but nothing is happening then it is probably mechanical and could very well be the gear that meshes up with your flywheel... if it doesnt make any noise when cranking then it is most likely electrical..also check the spark plugs and the coils...next the injectors...the injectors and spark plugs would cause it to turn off when driving too...you however need an oscilloscope to scope both the coils and injectors....
hope maybe that helps a bit let me know!
thanks, Adam
thanks, Adam
