Car won't start on cold mornings?
Old Sep 25, 2009 | 12:37 AM
jonkou888's Avatar
i still haven't figured it out. i dont think it is the battery, because i tried to jump it, and it didn't work. i swapped another battery inand it still didn't work, but i dunno if it's because the othe rbattery is dead because i've had it sitting for while. i will look into it again tmr or the next day on my day off. i just don't understand why only in the mornings. the rest of the day runs completely normal...i tried to listen this morning, i think i'm hearing a faint click coming from the fuel pump, but i'm not sure.
Old Sep 25, 2009 | 03:11 PM
JohnsS2000's Avatar
extremely unlikely to have a fuel pump fail. My 13 hondas I have had thus far , most with over 200k miles and 3 with over 300k miles never replaced a fuel pump before, relay yes
Old Sep 25, 2009 | 03:27 PM
turbo_slug's Avatar
you need to provide more details....
do you hear the fuel pump prime up when you turn the ignition to ON?
Old Sep 25, 2009 | 06:37 PM
jonkou888's Avatar
when it doesn't start, i don't hear the fuel pump prime. can anyone tell me how i can get to teh fuel pump relay? i can't seem to find anything on the forum. thanks
Old Sep 25, 2009 | 09:47 PM
Fast Jack's Avatar
I searched "fuel pump relay" and came up with lots of good info and pics from the "Electronics Helms Book".Try your search again.Also read about why u should check the relay first before changing the fuel pump and the tests to run to see if your getting power to the fuel pump.The relay could even just be loose.If the fuel pump doesn't prime when u turn the key, then my original diagnosis was most likely correct.Count it Keep us updated.
Old Sep 26, 2009 | 08:58 AM
jyeung528's Avatar
let us know what you find out. did you check the ground wire?
what noise do you hear if any?
Old Oct 3, 2009 | 01:22 PM
jonkou888's Avatar
sorry it took so long guys. i went to the junk yard yesterday and picked up the fuel pump main relay. swapped it last night and everything seems to be working fine so far. thanks for all your help .
joefish1298
Mar 30, 2021 12:55 AM
jonkou888
Feb 3, 2017 03:48 PM
Lou-AP1
May 30, 2015 08:28 AM
blink962
Jun 6, 2013 02:36 AM
sweetj
Feb 4, 2004 10:51 AM
