caster wont adjust
Old Jul 10, 2010 | 07:30 PM
vtec4life57's Avatar
Default caster wont adjust
took my car to a close shop i usually go to back in my civic days for an alignment.....
2001 ap1
100k
new tie rods sway bar links tien RA coilovers
spoon x brace
cusco side and rear brace
invidia test pipe ap2v1 wheels
other then that stock performance wise
o yah new axles and ap2 diff anyways....
spun out nicked a curb rear driver wheel at a local cfcrc event
hit the curb no more then 5mph didnt see any effect in the car besides a slight camber difference so instant thought was i bent something in the rear... took it home squared away the camber issue (loosened the bolt i tighted it up to match the other side all is well)
so taking the car to the shop this morning and on the alignment rack made him do the rear straightened it out for me nothing seems to be bent (wanted to go with aftermarket camber kit anyways) so rear sitting nice negative 2.2 and 2.4 passenger side good as we can get it witch is fine.
toe all in spec.
moving on to the front.
camber 1.5 perfect both sides
toe is perfect at 0
but we went to set castor and we ran into a HUGE problem!!!!!
fr driver side is sitting at a -4.2 passenger sitting at a -5.8
we tried everything the driver side wouldnt kick out more then negative 4.2
when i spun out i touched the rear barely not the front.... everything else is good car drives well... and doesnt pull any side and still smooth on highway.... but i do track the car and want to continue to running my spec alignments.... has anyone had this problem with castor? i know castor doesnt play a big roll as other specs do but it does play a roll on the track. i dont think anything is bent but who knows. this is the only place i brought the car to and havent taken it to a local race shop yet. wanted to hop on here for some advice.....
more camber i thought the more caster i thought i would get but for some reason the driver side front is way off almost by 2.0 degrees.... any help would be great hoping an easy fix!
Old Jul 10, 2010 | 07:41 PM
twohoos's Avatar
Er, there's no such thing as rear caster.
If you can't get at least -5 caster on one of the fronts then it's possible the lower A-arm is slightly bent (wouldn't be noticeable to the eye). It's a secondary effect; not dangerous, just not ideal. Might cost you a few tenths per lap.
Old Jul 10, 2010 | 07:52 PM
tenths is that stupid 335i im trying to beat
Old Jul 10, 2010 | 07:55 PM
hmmm im going to try and fix it and maybe, if i come across a deal for a front lower control arm id pick one up. but i was also doing some heavy research were they say upper arm? hmmm its just bothering me
fr driver 4.2 fr passenger 5.6
damn it! man i just got the damn car dialed!
on the alignment rack we got to the point were the damn adjuster bolt wouldnt do much either...
Old Jul 10, 2010 | 10:08 PM
INTJ's Avatar
bent arm.
Old Jul 11, 2010 | 08:34 AM
Great guess il have to deal with it for now.... Should I see any effects in tire wear or like u said just isn't ideal as it should be
Old Jul 11, 2010 | 01:42 PM
INTJ's Avatar
I'd just replace it, knowing its off will just drive you insane.
Mok
Jan 1, 2011 06:02 PM
VolkMan
Dec 21, 2009 12:56 PM
rudeS2k
Mar 11, 2008 05:47 AM
elude
Oct 14, 2005 01:32 AM
p0pe
Feb 4, 2005 10:32 AM
