Cat or O2 sensor?
Old Jun 24, 2019 | 10:09 AM
Jub's Avatar
Jub
Default Cat or O2 sensor?
I did an autocross yesterday (stock 06 S2000, 95k miles) with just 4 runs and when starting my car to leave, my CEL stayed on. I had the codes read and cleared but it came back almost immediately. I received the codes listed out below:
- P0138 - Oxygen sensor high voltage, bank 1, sensor 2
- P0137 - Oxygen sensor low voltage, bank 1, sensor 2
I'm wondering if it is the cat or O2 sensor. I don't hear any rattling from the cat to indicate that the innards have fallen apart. I'm a bit confused that the sensor has both high and low voltage. Anyone have experience with this? I'm wondering if I should begin tracking down a cat or just replacing the O2 sensor. I'd appreciate anyone's input that has experience with these codes.
Old Jun 24, 2019 | 10:54 AM
Deckoz's Avatar
I would just replace the O2 sensor... they're cheap vs a cat even aftermarket. They go bad, it happens.
Old Jun 24, 2019 | 01:26 PM
Jub's Avatar
Jub
OEM DENSO secondary O2 sensor is $300+ dollars. There is a Walker unit available for < $100. I usually go OEM but for less than 1/3 the price, I may consider. Does anyone have experience with a Walker O2 sensor? I'm also a bit concerned that if my cat is bad, it could take out a new O2 sensor, meaning that I'd have to buy a cat and another new O2 sensor.
Just a few weeks ago, I saw a low miles, used cat on craigslist near me. I almost bought it as a spare but did not...
Old Jun 24, 2019 | 07:35 PM
jiepo's Avatar
You can get some cheap O2 sensors off of Rockauto.
I'd go with the Denso or NTK
Old Jun 25, 2019 | 06:11 AM
Deckoz's Avatar
yea from honda its expensive...
just buy a denso with the same part number for like 50 bucks. the primary is like 90.
i doubt your cat is bad. the 2nd core should come loose and rattle before your cat core stops igniting
Old Jun 25, 2019 | 05:24 PM
Jub's Avatar
Jub
Thank you all for the help. Some reason, I thought I was seeing the same price for the DENSO direct unit as I was for Honda. I just looked it up again and grabbed one for $91 on Amazon. I did also make a deal for an OEM cat from a forum member. I'd like to have a backup while they're still available. I get the feeling that over the next couple of years it will get harder and harder to find parted out S2k's and good OEM parts.
Old Aug 8, 2019 | 11:26 AM
Jub's Avatar
Jub
Well, my cat ended up being bad. The 2nd core came loose and knocked into the O2 sensor. I was able to change it out with my OEM replacement. I'm going to look into securing the 2nd core and fixing the old cat to have as a backup. O2 and cat replaced, no more CEL!
s2kbtos
Dec 17, 2017 03:08 PM
RichSouth
Mar 18, 2013 01:35 PM
jshimer23
Jul 7, 2011 03:40 PM
nicku
Oct 2, 2006 05:54 PM
Ooalloems2koO
Apr 19, 2005 03:38 PM
