Cat/TP spring bolt
Old Mar 5, 2010 | 02:46 AM
cpl_allen's Avatar
Default Cat/TP spring bolt
So i was adjusting the hangers on my exhaust tonight and re bolting everything down, and I noticed that the springs around the flex bolt was just loose not doing much of anything. probably just rattling around down there making noise.
I also noticed that some carbon splash on the underside where there is an exhaust leak from the header to the testpipe. I took the springs off and threw some washers on to snug the header to the tp to get a good seal. The question is why is this part flexible to begin with? Why wouldnt you want that completely sealed off? Maybe the fitment of my t1r header/exhaust doesnt mate up right with my invidia tp. Was it a bad idea to snug this down?
Old Mar 5, 2010 | 04:35 AM
AngryTurtle's Avatar
Now your header and/or bolts on the head may crack.
Old Mar 5, 2010 | 05:11 AM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
Something is not assembled right.
The spring loaded clamp system is the most bulletproof design out there.
Get the springs installed right. They should compress 75% or so, but dont let the spring coils touch each other.
Old Mar 5, 2010 | 02:00 PM
cpl_allen's Avatar
"but dont let the spring coils touch each other. "
Old Mar 5, 2010 | 02:15 PM
SOHCmyDOHC's Avatar
They need some room to flex. If they touch no there is no room to flex. It would be just like bolting it down w/o the springs
Old Mar 5, 2010 | 02:29 PM
CKit's Avatar
He means, "Don't compress each individual spring to the point where each turn of the spring is compressed against the next turn (e.g. fully compressed)."
Sounds like you may be missing a gasket?
Old Mar 5, 2010 | 05:21 PM
cpl_allen's Avatar
Im using everything that came with the stuff I bought. The invidia tp just doesnt seem to have a lip that is thick enough to catch the springs. The only way that the springs are compressed at all is if i pry the tp away from the header. Otherwise they are just loose. I'll try to get pictures of it tomorrow.
Old Mar 5, 2010 | 08:20 PM
zeroptzero's Avatar
the stock flanges are probably thicker than the ones on the new setup no allowing the springs to compress now. The OEM bolts and springs were really made for the OEM sysytem , they may not swap over to every aftermarket setup. The flexible design allows things to move as the engine moves and as other parts move , rigid parts may fail in the long term.
Old Mar 6, 2010 | 06:15 AM
cpl_allen's Avatar
So if that is the case, there shouldnt be any foul with me putting a washer on on the spring side to at least give the spring a little pressure, but still have some room for flexibility
Old Mar 6, 2010 | 08:06 PM
zeroptzero's Avatar
you're right there is no harm in doing that, but there isn't any benefit over a new set of shorter rigid bolts/nuts either.
On the factory setup the wide part of the bolt passes through the cat flange hole without touching the flange (as the hole is larger than the bolt), the bolt mates up to the back side of the header flange. The the springs mate with the cat. flange as they are larger than the bolt holes, thus giving that bit of flexibilty if parts need to move. On your setup you likely don't have a larger hole on the TP side, thus it will act as a rigid bolt setup, so not any different than if you installed a set of shorter bolts/nuts.
KFC-AWD
Oct 10, 2016 03:24 PM
ash2k
May 25, 2009 09:07 PM
s1lentGPW
Mar 1, 2008 12:17 AM
Red_Ohio_Rocket
Jan 27, 2003 07:55 AM
