A few Header and exhaust install questions... Help needed
do i need to replace the self locking nuts that bolt header on, or can I reuse the original ones??
to those with Spoon Exhaust... What is torque for the bolts that attaches resinator pipe to rear exhaust pipe??
Thanks
Thanks
Re-use the header bolts. SELF-LOCKING NUT8 x 1.25 mm 31 Nm (3.2 kgf/m, 23 lbf/ft)
Spring bolts: 8 x 1.25 mm, 22 Nm (2.2 kgf/m, 16 lbf/ft) Replace.Tighten the bolts in steps, alternating side-to-side.
Aft side of the cat: SELF-LOCKING NUT10 x 1.25 mm 33 Nm (3.4 kgf/m, 25 lbf/ft) Replace.
3 different bolts listed. Ones that go on the header to the engine block.
Ones that are spring loaded(those go between the header and the cat
the ones that go between the cat and cat back. Dunno if you can use the gasket again.
Alexander Startsev
Apr 3, 2016 09:22 PM
