Catalytic Converter Bolts
Old Apr 9, 2004 | 11:10 AM
Fyrestrike's Avatar
Default Catalytic Converter Bolts
Are the bolts that attach the Cat to the exhaust removeable? Mine are done after 3 different exhausts and need replacing.
Old Apr 9, 2004 | 11:21 AM
xviper's Avatar
They are kind of a pressure fit, not too unlike the wheel studs. You can "hammer" them out.
Old Apr 9, 2004 | 11:28 AM
Fyrestrike's Avatar
Alright, I'll try that.
Old Apr 9, 2004 | 06:12 PM
ItalianBucwheat's Avatar
once they are out they can be a pain to get back in. They do come out and you will need a hammer (helps if the bolts are cold and ya spray some lube). If ya have trouble fitting the new ones ya just have to file the crud out of the opening.
Old Apr 10, 2004 | 12:33 AM
mikecl713's Avatar
easy to put in and take out
use a hammer and also use some wd-40
Old Apr 10, 2004 | 06:11 PM
jackhoff's Avatar
^^agreed, i just sprayed the bolts with alot of wd-40 and they came out pretty easy
solitarycheese
Oct 12, 2018 03:09 PM
wysongca
Apr 21, 2009 06:32 PM
JspecVtec
Nov 6, 2008 09:46 AM
vader1
Mar 25, 2008 01:12 PM
pjkwong
Jan 24, 2006 03:57 PM
