Replacing three bolts on catalytic converter
Old Oct 12, 2018 | 09:31 AM
solitarycheese's Avatar
Default Replacing three bolts on catalytic converter
Hey all, I bought a used OEM cat to replace mine. The previous owner had to cut the splined in bolts on the back of the cat that connects them to the exhaust. I managed to hammer them all out, but I need new bolts and nuts now.
Anyone know what size these are? Can I use any old bolts from Home Depot that fit, or is material a concern?
Thanks!
Old Oct 12, 2018 | 10:25 AM
Cossa's Avatar
Not sure which bolts you are referring to but here's the diagram and parts...
Old Oct 12, 2018 | 10:29 AM
It's part #3 in that diagram, 18176-P08-003. $50 shipped for 3 bolts seems a little expensive, wondering if generic hardware will work.
Old Oct 12, 2018 | 12:10 PM
flanders's Avatar
Using regular M10 nuts and bolts shouldn't be a problem, that's what I would have done.
Maybe not the cheapest stuff, but 8.8 grade should be more than enough,
Old Oct 12, 2018 | 12:58 PM
Chuck S's Avatar
Just drill or pound out the studs and substitute appropriate size bolts, lock washers, and nuts. Aftermarket cats and test pipes use this method and it works fine. I suspect this was a manufacturing feature, not a performance feature.
-- Chuck
Old Oct 12, 2018 | 01:14 PM
darcyw's Avatar
If you're feeling super awesome, find stainless hardware. Heck, the local muffler shop will be able to do it easily.
good luck
daryc
Old Oct 12, 2018 | 01:36 PM
noodels's Avatar
Should have left the oem ones in there,mine are 14 yrs old and still ok,the other Honda 20 yrs old and still ok..
Old Oct 12, 2018 | 03:09 PM
B serious's Avatar
Mcmaster carr sells JIS spec high strength steel class 10.9 flange bolts and flange nuts - same standard honda uses.
Use anti seize to install them and don't be a gorilla when you tighten them. I think they call out 20LB FT....which is probably close to the max torque recommended for those bolts with grease applied.
Or use stainless steel ones and anti seize and a lower torque value. SS won't be as strong....but you're not installing a structural part.
POG
Jun 7, 2013 12:12 PM
wysongca
Apr 21, 2009 06:32 PM
9000revolutions
Jan 31, 2009 04:37 PM
G2k
Mar 15, 2008 03:47 PM
MuGeN_S2k
Apr 27, 2006 02:27 PM
