CEL advice
Old Mar 6, 2022 | 01:52 AM
Speed2Kill's Avatar
Default CEL advice
I was running on racetrack yesterday in straight line WOT when the throttle went away and car went into limp home mode. I managed to coast back to the pits.
VSA Light and triangle came in as well as CEL.
Pulled codes: P2101 and P2176.
I tried clearing codes and disconnecting battery but P2176 comes back immediately and the VSA lights turn on again within a second of starting up. It sits at 1500 RPM and won't rev over 3000.
Electrical connections to throttle cable and throttle body look in good shape. Aside from replacing the pedal position sensor (of which I don't have a spare handy) any thoughts?
Thanks!
Old Mar 6, 2022 | 02:18 AM
RolanTHUNDER's Avatar
The car is in limp mode. Try to find someone willing to lend you their APPS for a test. Although unlikely, wiring to this sensor may have gotten frayed. Worth a close look.
What's the car tuned on?
Old Mar 6, 2022 | 03:26 AM
Speed2Kill's Avatar
I'm the only S2000 at this event so no go there. I looked at the wiring but I'll take another closer look.
​​​​​​It is tuned with Hondata flash pro on 93 octane.
Old Mar 9, 2022 | 11:19 AM
Speed2Kill's Avatar
Bumping my own thread. I replace the APPS sensor without any change. I cleaned the throttle body and inspected all electrical connections which seemed to be in good shape. Service manual has the next step being replacing the throttle body which is over $1000 for the part. Anyone have ideas before I start replacing expensive things?things. Really appreciate it.
Old Mar 9, 2022 | 01:13 PM
noodels's Avatar
maybe get TB repaired,do they come to bits,its only a potentiometer ! have it tested
can buy part also<$130>,shows code 2138 here?
Throttle position sensor failure & repair - S2KI Honda S2000 Forums
Old Mar 9, 2022 | 01:38 PM
Speed2Kill's Avatar
Thanks but it isn't the throttle position sensor. I replaced that and it did not change anything.
Old Mar 9, 2022 | 06:03 PM
noodels's Avatar
Ok
Armand
Jan 25, 2008 01:31 AM
vjarnot
Dec 10, 2007 05:34 AM
garfus99
Aug 27, 2007 03:26 PM
WarrenW
Aug 14, 2006 04:04 PM
