CEL after installing header
Old Aug 8, 2007 | 12:43 PM
synergytone's Avatar
Default CEL after installing header
Installed an aftermarket header and got the following CEL:
P0132 Primary Heated Oxygen Sensor (Primary HO2S) (Sensor 1) Circuit High Voltage
I've reset the ECU and it still throws the code. The only possible time something could have went wrong is during the install, the OEM header was hanging by the O2 wire for a bit.
Any ideas/suggestions?
Old Aug 8, 2007 | 01:42 PM
eflove's Avatar
from what you have said i would check for a loose wire or connection. Thats what it says in the book. It can be your o2 loose wire or ecu thats it. ecus dont really go bad. like 99% of the time its not a ecu.
Old Aug 8, 2007 | 03:08 PM
That's what I'm thinking...
Stupid question, but where does the primary O2 plug into the car? I tried following the wire from the sensor up, but it went behind the tranny and I didn't have a good angle under the car.
Old Aug 8, 2007 | 11:00 PM
Bump for more help
Old Aug 14, 2007 | 07:17 AM
Bump again
Old Aug 14, 2007 | 10:52 AM
iDomN8U's Avatar
Read this first:
https://www.s2ki.com/forums/index.php?showtopic=516396
Old Aug 14, 2007 | 05:23 PM
SOHCmyDOHC's Avatar
Primary O2 plug is different than the secondary O2 sensor so you can't switch plugs.
Why did you let the header hang on w/ the O2 sensor? Tha's what probably jacked you up.
Old Aug 15, 2007 | 09:33 AM
MacGyver's Avatar
The stock header weighs like 24 pounds... allowing an electrical connection to hold that kind of weight was a bad decision. check both ends of the wiring to make sure it hasn't pulled out of the connector, then make sure each wire hasn't frayed or pulled out of each crimp, then make sure any edge it might have rubbed on didn't rub of the insulation.
The good news is, if the sensor is fubar'ed, you can replace them for a little more than $100.
Old Aug 15, 2007 | 04:08 PM
Happened by accident during the install (had no help). It was only for a brief period of time before I saw it and took the load off the sensor wires.
Do you guys know where the sensor plugs into - I tried following the wires and they disappear above the tranny.
adriangb
Jan 26, 2018 06:17 AM
RedChili
Dec 9, 2011 06:35 PM
NilosJDMAP1
Mar 21, 2011 05:12 PM
Boofster
Oct 2, 2007 12:11 PM
Black Sheep
May 4, 2006 04:12 PM
