CEL AGAIN! Misfire
Originally Posted by YELLOW JACKET,Oct 23 2009, 11:19 AM
--snip-- for tps, turn your multimeter to ohms. disconnect the tps and hook jumpers to the pins of the tps. move the throttle body and see if your ohms reading change. if they do, its possible its fine. if not, than its bad. hope this helps. good luck.
It's a random missfire detection code the 1399 i have this same problem
it doesnt do anything to the performance of the car nor is it bad for it.
the code is only on start up or low idel.
The honda computer told me it was a low injector pulse reading so i'm waiting on replacing my injectors to see fi thats the problem.
I'm not exactly sure on the terminolagy, but it has something to do with the volts or soemethiing on the injectors dropping. is what the journeymen at honda told me.
if the injector pulsewidth on the hds is low then the computer is telling it to be low. And replacing
The injecotrs isn't going to fix it, unless the spray pattern is so bad at low duty cycle/pulse width
Then yes it would fix the idling misfire
yeah i deff wouldnt jump the gun on changing parts left and right, obviously thats gotten you nowhere...so far you have waisted your money with no permanent fix...take it to honda, see what they find.. do you feel a misfire or any hicups threwout the rpm range???
Well I took the car to honda today, it looks like the problem is either my map sensor or a bad valve adjustment. The map sensor with the car warmed up at idle is reading 1.01v, the tech at honda told me that it should be .88v. He said it could also be caused because my valves are too tight. I would doubt it needs a valve adjustment because I just had one done recently. Does this make sense, should I order a new map sensor?
Oh yea at idle I can hear the car hiccup slightly every 5-10 seconds, I originally thought it was an exaust issue but I guess its due to the misfire.
Originally Posted by ericb25,Oct 23 2009, 11:15 PM
The plugs are pretty new, I replaced them less than 5k ago
take it to honda. save some $.
