CEL Air Injection
Old Feb 3, 2005 | 06:15 AM
EriS2k's Avatar
Default CEL Air Injection
WTF is that>
Old Feb 3, 2005 | 06:35 AM
Dante(suzuka)'s Avatar
What was the code? 0410, 0411? I had that a while ago and it was related to the Secondary Air Injection system. To the best of my knowledge that's the system that puts fresh air into the catalytic converters to warm them up quickly on cold starts. It may have other functions as well. Just for reference mine turned out to be an electrical relay somewhere along the way that was faulty on very cold startups. I get the feeling that was a rare cause though. Hope this helps.
Old Feb 3, 2005 | 07:07 AM
EriS2k's Avatar
Yep! thats it!
Secondary Air Injection.........
Its a little Black Box with 2 cables that hook up to the Intake Manifold
Old Feb 3, 2005 | 11:28 AM
My car would get that CEL on very cold starts, but when I took it into the dealership they could never find a problem. Finally(a year later) I convinced them to take a real hard look at the whole wiring of the system and they tracked it to one little part. Keep in mind that's only one cause and I think other's have had similar codes for other problems. Let me know if you need anymore info.
Old Feb 3, 2005 | 11:30 AM
Amer's Avatar
Hey Dante, when you had thsi CEL about the air injection. On cold starts, does your car take longer to crank and start the engine?
Old Feb 4, 2005 | 06:35 AM
EriS2k's Avatar
Thanks for the help........
but what do i need to repair the CEL?
Old Feb 5, 2005 | 06:03 PM
Slows2k's Avatar
This is in the FAQ:
https://www.s2ki.com/forums/index.php?showtopic=105368
Misrouted Vacuum lines are the most likely cause.
Old Feb 9, 2005 | 08:47 AM
EriS2k's Avatar
Thanks Man!
CEL LIGHT is OFF!
Old Feb 10, 2005 | 06:32 AM
Amer, I don't recall that cold starts too any longer to crank the engine. I think that's a normal thing for the car to start slower when it get's below 30-40 degrees F?
Eri, what was the fix? We posted a couple suggestions up and I'd like to know exactly what fixed it. Thanks and good luck.
Old Feb 11, 2005 | 10:17 PM
EriS2k's Avatar
One of de vaccum lines was Missplaced.......
ll1l2l1l2lll
May 19, 2022 06:52 PM
project*stealth
May 6, 2013 08:36 PM
turbo_slug
Sep 17, 2009 05:37 PM
theblackpearl
Jun 6, 2009 02:23 PM
CwickStylz
Aug 31, 2006 11:46 AM
