CEL code P2A00, P0133
Old Nov 21, 2018 | 08:08 AM
wakathi's Avatar
Default CEL code P2A00, P0133
Hi Guys,
So, I just got new battery installed for the cold weather. After driving about 10 miles, I got the Check Engine Light (CEL) turned ON for the first time on my 2007 Honda s2000 with 100K miles.
I went to Autozone to pull the codes, and they printed out the following :
- P2A00 Air/Fuel Ratio (A/F) Sensor (Sensor 1) Circuit Range/Performance Problem
- P0133 A/F Sensor (Sensor 1) Malfunction/Slow Response
Also I observed something weird, when the CEL came ON, the no-seat-belt sign stopped blinking (i.e. when you drive without seat-belt) although it did still make that beeping sound.
Has anyone seen this before, or any suggestions on what to do next ?
Thanks
Old Nov 22, 2018 | 07:03 AM
wakathi's Avatar
Originally Posted by isthisusernameavailable
Some suggestions...
Easier stuff to check -- battery voltage okay? Fuses not blown? Wires/connector to primary air/fuel sensor (front sensor on the cat) look in okay shape and connected?
OBDII reader and shop manual also helpful for other things to test.
Thanks for the reply. Couple of doubts:
- Is the "primary air/fuel sensor" same as O2 sensor ?
- Which fuse controls the "seat-belt" light ? So that I can see if its blown or not....
-Matt
Mar 4, 2017 09:15 AM
2000silvers2k
Aug 25, 2016 09:02 AM
mister_s
Feb 1, 2016 03:35 PM
dwbrah
Sep 6, 2011 07:12 PM
jpdrain
Jun 12, 2009 06:59 PM
