CEL Primary O2 sensor question
Old Aug 18, 2016 | 07:24 AM
2000silvers2k's Avatar
Default CEL Primary O2 sensor question
Long story short, my car tossed a CEL a few weeks ago, I brought it a shop to run the code, cam back as the Primary O2 sensor. I drove the car 4-5 times after and the CEL stayed on.
I plunked down 300$ for a new O2 sensor.
The DAY its delivered i drive the car and notice the CEL went off.
My question to you guys is, Should i try to return the O2 sensor, or is it still worth installing it? Or do i keep it on hand for when it finally does crap out?
Old Aug 18, 2016 | 07:43 AM
windhund116's Avatar
I have a 2007 model. It kept flashing CEL P1172. Reset it. CEL would pop out in a few miles. Got more frequent.
Yes, the replacing the front air/fuel mixture sensor on exhaust solved the problem. No more P1172!
Old Aug 18, 2016 | 08:01 AM
I never reset the CEL though, it just went away on its own. thats the part that
Old Aug 19, 2016 | 12:19 PM
Slowcrash_101's Avatar
Lazy O2 sensor, sometimes works sometimes doesn't. It'll also cause evap codes because the engine gets flooded with gasoline.
Old Aug 19, 2016 | 05:42 PM
Car Analogy's Avatar
They get old, perform inconsistently. Replace.
Sent from my SM-G920P using IB AutoGroup
Old Aug 25, 2016 | 09:02 AM
solitarycheese's Avatar
Return it! You way overpaid. This is the OEM Denso part from Amazon for $95. Then go ahead and replace it https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Laguna_S2K
Aug 28, 2014 10:01 AM
ViperASR
Jan 10, 2013 06:19 PM
Lunacy
Jul 15, 2011 08:39 AM
FREEK
Jan 9, 2010 01:20 PM
