cel codes
Old Jan 10, 2007 | 07:47 PM
turismo25's Avatar
Default cel codes
car has 40000 miles on it. i ran a t1r test pipe for about 3000 miles, the test pipe has been off for 1000 miles and now i am getting a 0172(too rich) anyone have any suggestion of what it could be thanks
Old Jan 10, 2007 | 07:54 PM
Slows2k's Avatar
Is the car back to stock? What mods where un-done?
Old Jan 10, 2007 | 07:58 PM
turismo25's Avatar
toda header, t1r test pipe, apexi single cat back . car is back to stock now . had to put a new head on about 5000 miles ago.
Old Jan 10, 2007 | 08:05 PM
Slows2k's Avatar
Do you have any Freeze data from when the code was stored?
Old Jan 10, 2007 | 08:10 PM
turismo25's Avatar
sure don't
Old Jan 10, 2007 | 09:20 PM
Slows2k's Avatar
Have you reset the light? Does it come back on? Can you get the freeze data if it recodes?
Old Jan 10, 2007 | 09:26 PM
turismo25's Avatar
ok will do tomorrow. what info will it freeze. thanks for all you help
Old Jan 10, 2007 | 09:32 PM
Slows2k's Avatar
All the PCM data when the code sets
Old Jan 16, 2007 | 10:45 AM
kiowa132001's Avatar
Looking at a Honda S2000 Manual, the possibilities are:
fuel pressure regulator, fuel return pipe, fuel pump, fuel filter, primary HO2S, incorect valve lash, injectors, evap canister and purge valve. It all depends on fuel pressure. If any questions on diagnostics, feel free to pm me.
Old Jan 16, 2007 | 04:06 PM
Slows2k's Avatar
He's allready Pm'd me with the reset DTC's. He's got 2 bad 02 sensors.
