CEL on hard accel?
Old Nov 1, 2010 | 04:52 AM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
Personally I would go to Honda and get oem plugs...i know it may sound crazy that your brand new plugs are defective, but it can happen.
Old Nov 1, 2010 | 05:28 AM
wrecked's Avatar
Maybe one of the coils are going bad. If you scan the car, the code should be under pending codes. It should tell you which cylinder was missfiring. Take the coil out of that cylinder and swap it with a coil from a diffrent cylinder. Then do some wot pulls and check the code again. If the missilfire switched to the cylinder you swapped the elegd bad coil in, then that is your problem.
Old Nov 1, 2010 | 06:58 AM
Importedpower's Avatar
but how would that affect it? if it doesnt misfire outside of vtec? i drive it perfectly fine all day long until i hit vtec... but ill try, i need to get my dif and trans fluid swapped today, and then im picking up a code reader today aswell...
Old Nov 1, 2010 | 07:16 AM
wrecked's Avatar
Because it is harder for the coils to fire at 9000rpm as opposed to idle or 4000 rpm. Also, there is more pressure in the cylinders at higher rpm especially in a VTEC motor that switches to a higher lift cam lobe where there is more air and fuel in the way of the spark plug gap that the coil has to penetrate.
Old Nov 1, 2010 | 12:48 PM
ok im going to swap them around and see if that fixes anything, i know i need a valve adjustment aswell. buying a CEL scanner tomorrow, between this and my teg i need one. If that doesnt work then ill buy new plugs (and seals that go inside the tubes) and replace them and see if it fixes it
Old Nov 1, 2010 | 06:04 PM
Just noticed when i reset ECU after changing my oil, adding a new ram intake, diff fluid and trans fluid swap, that half of my fuses are one way, the other half are the other way... i dont think a fuse matters whether its in one way or the other right?
Old Nov 1, 2010 | 06:32 PM
wrecked's Avatar
Uhh as far as the amp rating numbers being in different directions?? No. lol
Old Nov 2, 2010 | 06:32 AM
just wondered, figured the current flowing through them could maybe cause one side to have a different resistance, and then if they got swapped it would change it.
Old Nov 3, 2010 | 03:52 AM
Ok so it gives me code P 1399 as "pending misfire on ANY CYLINDER"... so its not giving me a specific one... so ideas lol?
Old Nov 3, 2010 | 04:08 AM
Billman250's Avatar
Top Answer: 1
Change plugs yet?
Are you sure thats the only code? Sometimes you need to sift through a cheap code reder to get all codes.
