CEL help....pulled code w/o reader
Old Jun 19, 2008 | 04:26 AM
chimmike's Avatar
Default CEL help....pulled code w/o reader
So I'm driving to work this morning, and halfway through the commute, my CEL comes on.
03 AP1, just purchased a few days ago, installed a new battery 2 days ago.
Pulled the code using the jumper method, blinked 9 times, then nothing, blinked 9 times again, then nothing, blinked 9 times again, then nothing.
I'm pretty sure it was just repeating the code, but the only thing I got out of it was 9-0. I looked through the ultimate CEL thread (which, while being very good, is far from the "ultimate" in my opinion) and couldn't come up with a match.
Car ran normally. I didn't try to go into vtec after the code came (that and because it was raining), but the car ran just fine. I'm sure it's some stupid OBD2 code, but if anyone has any tips before I try to get some generic code from autozone, let me know.
IIRC, they don't even read codes for free anymore either.
Old Jun 19, 2008 | 06:28 AM
chimmike's Avatar
anybody?
Old Jun 19, 2008 | 09:47 AM
chimmike's Avatar
Okay, so the car pulled a P1456 code via a generic Actron scanner.
P1456 EVAP Emission Control System Leak Detected (Fuel Tank System)
according to the ultimate thread.
Any ideas? Maybe bad vac line or something?
I was wondering, last time I filled up the tank, I didn't get the "suction" sound.
Old Jun 19, 2008 | 10:50 AM
chimmike's Avatar
checked the gas cap, wasn't perfectly tight. tightened til I heard 5 clicks and reset the ECU. Will be able to tell later if it worked.
Old Jun 21, 2008 | 09:40 PM
Kirpich's Avatar
Yep, that should do the trick. Most EVAP porblems should be initially diagnosed beginning with the gascap 'click' treatment.
El S2000
Mar 8, 2014 02:05 PM
Importedpower
Nov 9, 2010 07:54 AM
bcohan
May 16, 2007 05:49 AM
FormerH22a4
Mar 14, 2002 06:30 PM
