Cel Light
Old Dec 10, 2006 | 05:09 PM
djpeak10's Avatar
Default Cel Light
The cel I got today is P0132 Bank 1 censor 1 (censor circuit High Volts).
What is this? I had a test pipe for a minute but I don't have a engine management so I was afraid I was running lean. So The only mods on my car is the Vortech supercharger stock boost, exhaust.
Also could this be from my yellow box speed calibrator not being hooked up properly?
Thanks,
Old Dec 10, 2006 | 06:37 PM
djpeak10's Avatar
Old Dec 11, 2006 | 08:05 AM
djpeak10's Avatar
Anyone, Anyone
Old Dec 11, 2006 | 08:14 AM
d-j's Avatar
d-j
Check the sticky at the top. Link
P0132 0 - 1 --------------- Primary Heated Oxygen Sensor Circuit High Voltage (Sensor 1)
Old Dec 11, 2006 | 08:17 AM
djpeak10's Avatar
Yeah I know that, however I am looking for someone with a manual to chime in and tell me what the process is to eliminate this.
Old Dec 11, 2006 | 08:21 AM
mxt_77's Avatar
Mmm... it sounds like an O2 Sensor issue... probably from the test pipe. Since you know the code, did you try resetting it and see if it comes back.
If you want to run a test pipe with the stock ECU and not get a CEL, you need to use one of the workarounds.
Old Dec 11, 2006 | 08:29 AM
djpeak10's Avatar
Yeah, I had a test pipe (Berk) with a cel fix but I still got a cel, so I added a anti fouler and it worked. But I took the test pipe off since i was worried I was running lean.
So now I am getting this cel with a stock Cat in.
And yes I reset the cel and It came back 3 days later.
Old Dec 11, 2006 | 08:54 AM
mxt_77's Avatar
Did you undo the "CEL fix" that you did previously? Did you take the anti-fouler off when you installed the O2 sensor on your stock cat? If so, is it possible you damaged the sensor when you re-installed it?
Old Dec 11, 2006 | 09:35 AM
djpeak10's Avatar
yes I took of the fix.
I thought bank 1 was the 02 sensor in the header, am I wrong? Does this cel refer to the 02 sensor in the cat?
Old Dec 11, 2006 | 09:43 AM
s2k dre's Avatar
test pipe aint gonna make it run lean, the ecu is gonna adjust the air fuel, ur num 1 o2 has to be changed thats all.
