CEL, misfire all 4 cyclinders - need suggestions
Symptoms so far:
1. CEL - 301, 302, 303, 304 (always those 4 codes)
2. car hesitates during acceleration(not always, but more than 50% of the time)
3. weird shaking during idle, sounds like it's going stall (not always, but more than 50%)
This problem has been going on now for about a month, and I've been trying to fix it myself. I've tired the following already, but to no avail:
1. compression test
2. leakdown test
3. new OEM spark plugs
4. borrowed another set of coil packs
Spoke with my mechanic and he said it could be the fuel pressure regulator. Any ideas or suggestions would be greatly appreciated. Thank you
1. compression test
2. leakdown test
Originally Posted by chrisesteban,Aug 29 2008, 02:18 PM
got the same problem.cars sitting in the garage now.
My mechanic doesn't have time to check the car out until Wednesday, so I'll keep you update with my situation.
Originally Posted by sunhita,Aug 29 2008, 02:20 PM
Also possible:
Bad Gas (mixed with water, R/M= <91 octane)
Bad wiring harness
Bad wiring harness
How would the wiring harness cause this? Thanks
