CEL P1259
Old Sep 21, 2006 | 07:02 AM
jackalope's Avatar
Default CEL P1259
Okay I'm getting p1259 Immobolizer to PCM signal error according to autozone. their handheld device said "air and fuel mixer or something to that effect.
any ideas?
according to the search of p1259, it is vtec engagement problem. I just added oil to the car last night, so it shouldnt be a problem if that is the case. any ideas?
Old Sep 21, 2006 | 07:53 AM
jackalope's Avatar
okay, well I went out to the car, unplugged the vtec solonoid (sp?) and replugged everything making sure it was snug. then i checked the oil level agian, put in another quart, reset the ECU...and bam problem solved.
no more CEL. wonder why the code says Immobilizer to PSM error though...
Old Sep 21, 2006 | 04:11 PM
Slows2k's Avatar
It has nothing to do with the immobilizer. Autozone's tester can't ID the code because it's manufacturer specific and the tester only does generic OBDII
#1 cause of this DTC is low oil level.
Old Jan 28, 2007 | 02:06 PM
Kyushin's Avatar
Banned
Having same problem at, just got car back from tuner and it seems sluggish. Didnt seem strong like boost, and i opened it up on the interstate and car totally died after 8k rpm, pulled over and restarted and got a CEL and pulled the code and found a P1259. Im not too familiar with the Vtec solenoid wiring but found one harness wasnt plugged in, being i dont know anything about installing these, does the vtec solenoid have 2 places for a plug or is one no longer used after installing a SC and oil pressure sensor (after market).
Old Jan 28, 2007 | 02:07 PM
Kyushin's Avatar
Banned
Sounds I try resetting the ECU and a Map wack?
Old Jan 28, 2007 | 03:10 PM
Slows2k's Avatar
No.
Are you using a VAFC?
have you checked the oil level?
Old Jan 28, 2007 | 04:42 PM
Kyushin's Avatar
Banned
Oil is fine, double and triple check it at everyfill up and usually after I come in at night. No Vfac,but I do have a CTSC, seems I found the problem. One of the harnesses going to the Vtec solenoid was disconnected, I connected the harness and the codes were cleared and now it runs like new! Just gotta do something about that cracked bracket now.
geekyjerry
Oct 2, 2016 04:20 PM
tph4m
Jun 16, 2015 07:22 AM
xrapidx
May 31, 2008 04:01 PM
Rollinx25
Dec 23, 2007 05:58 PM
buggy1129
Feb 8, 2007 12:09 PM
