CEL Question
Old Nov 2, 2005 | 06:15 PM
villain2000's Avatar
Originally Posted by Slows2k,Nov 2 2005, 08:30 PM
Untill you get the code, you are all guessing what the problem is.
If it's a P0420, your test pipe is the cause.
Will try to get the code pulled soon. It wont do any harm to run the car with the light on for now, right?
Old Nov 2, 2005 | 06:29 PM
Slows2k's Avatar
Usually you can continue to drive normally. But, there are exceptions to every rule. If the code is a P1259 for a VTEC failure, due to you having only 1 quart of oil in the motor You'd be pissed if someone said it was OK to drive. ( has happened before)
If it's not running like crap, running hot, and the oil is full, Drive normally untill you get the code to be certain.
Old Nov 2, 2005 | 06:31 PM
Thanks slow you're the best!! BTW - The car is running great. Really, better than ever. None of the symptoms you just mentioned.
Trent06
42
Jun 17, 2010 11:57 AM
Hamburglar
Oct 22, 2008 11:05 AM
Jamers99
Jun 16, 2007 09:44 PM
BobDigi7080
Apr 12, 2006 10:53 AM
freshs2k
Nov 29, 2005 07:01 PM
