CEL throowing code P1106
Old Aug 22, 2006 | 06:03 PM
REDRICE23's Avatar
Default CEL throowing code P1106
Hey so today my02 began trhowing a CEl i had the code run and it is P1106
heres the situation my car is completely stock nothing is done to it.
when you start the car its starts fine and goes right to idle however if you give it even the smallest rev it gose up and as soon as you let your foot off the gas the rpms drop completly and the engine dies, even with the cluth in or out. so driving every thime i get to a red ligt or what not the car dies, now if i hold the gas down when i take it out of gear and hold it at about 2000 rpms it runs like nothing is wrong... but the second you take your foot of the gas the rpms fall and the car dies. Like i said its also throwing the cel code of p1106
please help
Old Aug 22, 2006 | 07:35 PM
xviper's Avatar
That code is to do with the BARO sensor.
1. Reset the ECU by pulling the BACK UP fuse for 10 seconds.
2. Start the engine and hold rpm at 3000 (in neutral, no load) till rad fan comes on. Then let it idle.
3. Test drive with transmission in 4th gear.
4. Accelerate for 5 seconds at wide open throttle.
5. Does the code come back?
If YES, substitute a known good ECU and if symptoms go away, you need a new ECU.
If NO, it was temporary. Carry on.
Old Aug 22, 2006 | 07:43 PM
REDRICE23's Avatar
by pulling the back up fuse for the ecu does it mess with the coded keys for the ignition ?
Old Aug 22, 2006 | 07:51 PM
xviper's Avatar
No, it just resets the ECU to its default settings and erases the code. Putting in a "known good ECU" will require a new programming so your key will work.
Old Aug 22, 2006 | 08:30 PM
Slows2k's Avatar
Any Mods?
This DTC is common with Piggyback AF controllers and MAP signal clamp wiring gone bad.
Old Aug 22, 2006 | 08:33 PM
xviper's Avatar
Originally Posted by Slows2k,Aug 22 2006, 10:30 PM
Any Mods?
I can only hope he's not leaving anything out.
Old Aug 22, 2006 | 08:42 PM
Slows2k's Avatar
I gotta ask, just to make sure. Bad Baro sensors are exceptionally rare.
Old Aug 22, 2006 | 08:50 PM
xviper's Avatar
With what the potential cost could be, I'd recheck that code to make sure it wasn't mis-read.
Old Aug 22, 2006 | 09:07 PM
REDRICE23's Avatar
Originally Posted by Slows2k,Aug 22 2006, 08:30 PM
Any Mods?
no, no mods completly stock
slipstream444
Jan 11, 2014 11:14 AM
WarrenW
Nov 25, 2013 07:13 PM
psychoazn
Apr 26, 2012 08:32 AM
AROD
Nov 5, 2006 11:15 AM
mcomer
Jan 29, 2004 01:36 AM
