Changed diff fluid (concern)
Old May 16, 2013 | 01:44 PM
dv55xc's Avatar
Default Changed diff fluid (concern)
So today i changed my diff fluid with amsoil fluid. i only had one quart on hand and when i was pumping the fluid in to the diff i spilled some (pump failed due to high viscosity and high pressure). i was still able to get fluid in to the diff using a spare pump that i had but im concerned if we had to use the full quart in the diff. i pumped until fluid started coming out of the fill hole. reading the DIY youre supposed to pump until it starts running out of the hole. should i be worried? i drove it and it feels fine and there is no more noise coming from the diff but i just want to make sure im ok before i break something.
Old May 16, 2013 | 01:50 PM
HvRRZ's Avatar
you're fine
Old May 16, 2013 | 02:10 PM
ConanO'Brien's Avatar
yeah, you pump until stuff starts to come out of the hole (innuendo intentional)
Old May 16, 2013 | 02:13 PM
s2kmiami69's Avatar
assuming the car was level when you put the fluid in, yeah you did it right
Old May 16, 2013 | 02:25 PM
dv55xc's Avatar
Yeah it was level. Ok good just want to make sure. Thanks you guys!!!
Old May 16, 2013 | 08:21 PM
2003AP1's Avatar
It doesnt take a full quart I think its like .8 or .9 quarts.
RedCelica
Aug 27, 2016 02:48 PM
9K-S2K
Oct 27, 2008 03:26 PM
C4SxM5
May 13, 2006 03:10 PM
mic_crispy
Apr 11, 2006 04:59 PM
